Engine/Transmission (1994 - 1998) Identify this housing.
Engine/Transmission (1994 - 1998) CALIFORNIA Repair
I am trying to figure out what size housing this is. If you know the numbers please help. The ex side numbers are 3532214. On the compressor side I cant tell if thats an 18 or a 19 with a narf out of 9 in the casting. Its got a pit there. So ???? Thanks.
ah look into the flange side of the housing and cast into the inside wall should be a 12 or 14 or what ever size it is. . that looks to be a 12 from the size of it. . i haven't seen any 18. 5 or 21 cm watse gated housings... any they are way bigger then the one you have pictured there.
Hope this helps you,
thanks
Deo
Ok, what flange side does one look at? Wastegate end? turbo cartridge end? Manifold end? Sorry for my ignorance.
Daniel
the manifold side, inside the turbine port. . on the wall is the cast in size # you may have to clean the carbon out to see it. .
Thanks
Deo
