on my 99 2500 24 v I am having a rough idle only when it warms up and only at an idle the outside temp. doesn't make a difference I can start it up at 10 deg plugged in or not and it will idle fine until the engine warms up changed fuel filter have super chips programmer does it on all setting including stock installed FASS 150 pump changed ckp sensor installed BD turbo 4" exhaust K&N filter not all done to help problem but nothing helped hooked up to a reader no codes and all sensors looked to be ok need some ideas
