The mileage is not the issues, being 9 years old is a bigger factor. Electronics can fail at any time, failure rates go up with age. Dropping 200 rpms if idle speed shuld be instantly noticeable in engine tone and sound if you are used to a normal idle. With an FCA problem rarely will it drop and stay at a lower idle, it will idle up and down and that is easy to hear.
First question to answer is does it sound like the idle really dropped that low, or, does it bounce. If it doesn't thne it is back to cluster, CPS, ECU, data bus, and all the harnesses in between.
