My idle dropped recently so I turned it up by adjusting the screw on the linkage. I can't seem to get the idle to the right rpm, it's either a little too high or too low. Right now in gear with a. c. on it reads about an 1/8" above the 800 rpm tick mark. I believe it to be about 850-900 rpm.
Is the idle speed screw a regular screw with a locknut? I would like to remove it and check the threads, I believe that they are stripped in the area that I want to set it.
