Engine/Transmission (1994 - 1998) Idle springs for P7100.
Engine/Transmission (1998.5 - 2002) Trans line rubbing
Engine/Transmission (1994 - 1998) Help with EGT's please
I just got a pump back from the shop and as it is a new pump i will have to go through the process of adjusting the low speed fueling again. I always have a problem with being able to set the springs loose enough to get it to where it idles good and doesn't buck at slight throttle in low speed situations. Do the idle springs come in different rates, or is there stock only.
