CSkal said:Does the automatic idle-up feature still engage if the block heater is used, or would I have to use the on-demand high idle in this situation?
RRees said:p. s. How do you like your Jacobs E-Brake? I'm thinking of getting one.
RRees said:p. s. I checked with my local dealer and they want $1795. 00 installed for the factory approve Jacobs exhaust brake. I'm still thinking about that one.
RRees said:The block heater does work. My normal commute is only 11 miles to work.
I would guess (didn't actually check), that I only drove about 5 or 6 miles before the guage was near the 200 degree mark. Note: Outside air temp was about 28 degrees F. It was nice to have somewhat warm air right out of the driveway.
My truck is normally garaged, so that helps quite a bit too. Garage temp was 64 degrees F.
Prairie Dog said:Quick FYI, Running the eng with the block heater plugged in can result in a burned out heater element. Mechanic freind tells me it has something to do with bubbles or air pockets that cause the element to dry fire. I've seen it happen.
Scotty
JasonCzerak said:I'm sure a a minute of both the motor and block heater wont' hurt anything?
I some times let the truck cool after I pull into work/home and go plug it in and all that prior to shutting down.
Prairie Dog said:Your probably rite, it may not hurt it if the eng has been running awhile and then it's plugged in because the coolant wont have any air in it.
I just wish there was an indicator on the dash so you cant accidentily drive away with it plugged in. You only do that once (but that was when I drove a chevy so a busted grill only added to it's patina)
Cattletrkr said:Cold coolant hitting a hot heating element can break the element. DO NOT RUN YOUR ENGINE WITH THE HEATER PLUGGED IN. So says my mechanic.
