After I installed the TCI unit in my 93 I noticed two things right away - first was the stall speed was a little lower than before, and more noticable was that the engine actually dipped in the rpm's when the trans shifted. Before the engine would sit at 1800 rpm and never change rpm until it got up to about 60. It cruises at 70 mph at about 2000 rpm, and before you could bury your foot and the engine would just waste 300-400 rpm and get very little speed increase. Now if you bury your foot the turbo kicks in HARD and pulls to 80 in no time, and on up to 90 - then it runs out of rpm.
The engine actually runs at the same speed as before, but the stall in the converter when you want to accellerate is about 300 rpm lower. 70 mph = 2000 rpm, and mashed from 70-80 mph stalls at about 2150 rpm and levels out at about 2100 rpm. Big improvement on stall speed and power transfer, but nearly same rpm when not trying to accelerate.
Oh yes, also BIG improvement on hills. I'm towing the hot rod to the track next weekend, about a 3 hour trip each way, and I'll know for sure how much better it really works.
Full power pull stalls the converter at about 1600-1700 rpm, and gets up to speed quickly. Let's just say that for the $350 it cost for the converter I am very happy with the results. I also have a 12" TCI unit in my dually with a '63 big block 413 and a bulletproof 727, and it'll roast the tires if I really want to.
I have no doubt the DTT is the best out there, but for my needs the TCI is working great.
So, my two cents worth.
Suerte - Sam
