Ign,key reader & chime malfuntion
Splitting 'Other'
Geno's cover contest
I am having a problem with the key chime or key reader, The key is pulled out of the switch and a chime comes on as if the key was left in the switch when you open the door. I move on and shut the door and click on the lock alarm with my fob and nothing
happens. I open the door and reinsert the key into the switch and slowly pull
the ing. key in and out and chime goes off normal. some times i have to repeat this process
2 to-4 times before the reader picks up that the key is removed
#Note if you are in a rush and turn the truck off and jump out of the truck and start walking
of away and press key the fob to lock the truck it wont trigger the alarm if the
key reader was to slow to to read the key. should i change the ingnition swith or the key tumbler . Any body have this happen to you#@$%!
