Where exactly do you tap in the back of fuse harness for ignition on? I found a fairly large wire (I believe it was pink with red stripe) that will power up on ignition. However, I don’t want to tap into something that will cause interference with the ECM or something electrical sensitive that will kill the truck.
I would be nice if I can locate the cigarette lighter from the wire cluster to tap into since it is a 20 amp. Does anyone know which one of those wires is the cigarette lighter? Where do you all tap into? Thanks for all your expert help.
