Gents;
I am brand new here so bear with me until I get my bearings around the form. The issue I have is on an 04 quad cab &5. 9 4x4. The problem is the ignition solenoid. It does not work, nor does the steering wheel lock when the truck is turned off. The way I start the truck is to flip a little toggle swith to the on position and then use the key an normal. To shut down, turn em both off and that is it. I found this problem in the middle nowhere, Northern Ontario,Canada the day before I was to load up and travel back to Ohio! At any rate I called the dealed and was infomed that there was over 3500 on back order, about 100 en route with no time of arrival. The part is made by bosch. I dont really mind the set up I have but it would be nice to have everything working like it should. Please share yoiu wealth of knowledge with me on this matter.
Thanks
Fred T
Thanks
Fred T
