ignition switch problems
Hose/Belt life
2003 Fuel Pump Troubles - Again
I have a 2003 slt 3500 quad cab recently the ignition switch got hard to move back to acc. then I noticed with the ignition in the off position the blower motor to the hvac still stays running ,radio gauges all turn off in ideas would help thanks
If the gear shift level is working correctly, its probably the Key cylinder,its a little tricky to tear down. The PDF exceeds (167KB) the allowable amount to Post, PM your Email I will send it (15 pages PDF)
I'm having the same issue. It's really starting to get to me because I always have to check and see if I turned the heater off. Otherwise I end up with a dead truck in the morning. Can you send that to me also -- email address removed --
I'm having the same problem with blower motor continuing to run after key off. Thanks -- email address removed --
