Ok all, let me add to the ever increasing topics on this 1st gen forum, we might have to have the split forums, engine/transmission only, everything else? Ok my problem is on my 89. 'Mr. Reliable', as he's a he cause 'he' stills has his critical body parts. .
, failed me the other night. Fired right up, no block heater, 15*f, idle 10mins, drive 10 mins to bar, turn him off. Come back after about an hour, get in have dome light, all lights, door buzzer, radio etc, turn key to start position, nothing, no crank, no engine turning over, message center lights come on when i hold key turned over, they go out when key is released- as normal. Engine is warm, no need for grid heat. Only noise is what i believe to be the starter relay clicking when I turn key over, comin from the driver side fender area. No flash light. Pop hood, do the ole wiggle everything. I'm thinking its the ignition switch. Get a buddy to come and pull start me. Drive home to switch trucks for the rest of the night. Shut it down. Wait a min, try starting, fires right up, repeat 4 times and it fires right up. Come out next morning, 10*f, cycle grids twice, fires right up. Take it out that night, park it, shut if off, come back, same problem, no start. This time I'm not calling someone, I assume its a loose ignition wire or something, I hold the key over in start position, and reach under dash and start wiggling wires, after a min or so, zoom it fires right up. Again no flashlite, so I dont know what wire I played with. Went out today, fires right up, ok lets try something different. Shut if off, wiggle wires underneath the dash, try to start now, no go, no start.
Heres a little background, for some time, I've had an intermittent heater a/c blower problem. Start it up, no blower, shut it off, key in run position, heater blows, start back up, no blower. After a couple start ups i would get the blower to work with truck running. Now after searching the archives, it looks the heater blower and ignition switch work together? Or one runs off the other? And my battery terminals are clean, treated with terminal protector. Same with all relays, clean, protected, same at starter, both terminals clean, free of corrosion, protected with spray on anti-corrosion stuff. Clutch interlock switch has been cut and spliced together to bypass it. Engine temp or outside temp hasnt had an effect on this problem. This no start deal has not been a recurring problem, its just started this weekend.
So, I'm leaning towards the ign switch. What do yall think? I hope I've not confused anyone with all my run on sentances. If it is the ign switch, is it expensive? TIA. Bill
