II Dual Feed line? $550?
nv5600 oil change?
VG (Variable Geometry) Turbo
What is up with the price of this line. $550 for a line that can handle 30,000psi. My local tractor shop said they could make one for less than $100 easy. I dont know if II is the only company that makes this or what. But the price is 1/3 of a complete CP3? :eek: :eek:
$100... ... ... ..... i want one too :-laf
That's the price.
It includes the fittings for the CP3, the line with female fittings on each end, and a fitting for the rail.
~Wes~
p. s. Good to see you're in good health Rob. I was beginning to wonder.
I've heard this hose is flexible, not rigid tubing. I haven't seen one, but if it is hose, then the only thing I know of that can hold that kind of pressure is Parker Polyflex. For the fitting you can remove one of the two large torx plugs and replace it with another stock fitting to adapt to the hose/tube you are using.
