I'll ask again
Power Pedals and....
New truck !!!!!!!
Has anyone had trouble finding replacement tires for the 03 dually? Goodyear is the only one that makes the 235/80R/17 for the duallys that I know of. There are only 60 in Goodyear warehouses across the US and others scattered in local tire shops, none in my area. Goodyear does not have this tire in production at the present time. A wider tire will not work because of the space between the duals. Has anyone heard of another 10 ply tire that will work on the duallys.
According to the dodge website, you can also run 265-70-17. There is a much wider selection in this size. Not all are load range E however.
:confused: I thought the 265/70R17 size was for single rear wheel only. If we can use it on our duallies, it will give us a MUCH better selection of replacement tires. :)
Your dually wheels are only 6 inchs wide. The 265 will require a 7 to 8 inch wide wheel.
EB, are you in need of tires now? I know you put some miles on your trucks. I have 7 sitting around collecting dust, with 12,000 miles on 6 and 0 miles on #7.
