illumination of power door and window switches
Newby
2500 RPM for 2500 miles
on my '94 there is no illumination on the power lock/window switches at the door panels
and it is a nice feature to have, so i was wandering if there was a later year model that does have the illumination where the switches could be changed out to fit the '94 model openings... thanks in advance...
'94 2500 4x4 3:54 auto prime-loc tst #6/230 DiPricol egt/boost
The 94-97 are the same and the 98 and newer are the same except the 98's don't have the auto down. The connections are not interchangable. It might be able to be done but you would have to do some splicing, extra wire, and get a hold of the proper connectors
98. 5 3500 SLT Quad Dually 4x4. 3:54 Auto, Waterfall Blk on red. Custom dually flaps, Rhino lining, All acc's w/leather, Muth signal mirrors, Catz MSC's, 55watt back up lights, Optima Red Tops,
BD exhaust brake, Banks EGT/Boost/Temp gauges, Mag-Hytec DC&TP, SS bug screen and fender trim,SS Stull diamond line running boards, SS 4" turn down.
My Dually
What I'd like is illuminated cruise control switches on the steering wheel. I have not checked for sure to see if they are supposed to be but mine aren't and that seems like a terrible oversight by DC.
Late '01 2500 2WD, QC, LB, HO 6 Sp. , SLT/Sport, 3. 55 Open Diff, Mods: PowerEdge EZ w/elbow. Jardine 4 inch exhaust. Banks (DynaFact) Boost and EGT gauges. ATS exhaust manifold with Jet Hot 2000. Amsoil dual bypass filter. Oh yeah, and cup smoothie.
One thing you guys might consider experimenting with is clear, glow in the dark paint. I got some from the hardware store about five years ago put it on some light switches around the house, it's sill glowing, you can't see it at all in the light.
