Went to start truck a little while ago and it wouldn't start. Looks like the lift pump is dying. I knew it was on its way out, since my pressure has been slowly dropping over the last year. In the last few weeks the truck would hesitate on start-up after sitting a while. I noticed the FP slow to come up when this happened. Just replaced the fuel filter even though I new it was good - NG. When I bump the starter, the pump sounds raspy. Mostly it will only get the FP guage up to about 3 pounds, sometimes 8-10 (which is normal FP at this point). When I crank the engine it drops to 0. I'm thinking there must be a check valve in the system somewhere. If so, where? I thought the VP would still suck fuel for a while even with a dead LP. However, the tank is near empty, which makes it harder to suck fuel. I've noticed my FP jump almost 5 pounds when I fill the tank.
What it comes down to is: How do you start this truck once it has sucked air?
Roy
Roy
