I'm looking for a 12cm^2 housing
Tensioner pulley for NON A/C
Fuel adj. screw... Is it welded in?
Any one have any of the 12's or 14's laying around? I am done guessing how my truck will run with this housing and am going to try it :rolleyes:
Also, guys who have installed it: Banks down pipe or make the stock one work?
Oh yeah, for the wastegate actuator, where are you running the line? To the boost pick up on the intake manifold or are you tapping the compressor housing and running a short line?
Thanks,
Russell
14 cm turbo housing
Russell, I installed a wastegated 14 cm housing on my 93 last year. Shortened/rewelded the front engine pipe 1-1/2 inches to clear the heater box. Ran the wastegate lineacross the top of the engine between valve covers, connected to a tee fitting on the intake manifold that is also connected to my boost gauge. Works well, good luck..... Rick.
Why?
Not sure why you would want to hook up the wastegate. Max boost seems to be dependant on fueling. I had my stock pipe cut and rewelded to fit. Didn't like it touching the firewall.
I think I have one of those little darlin's. I ordered one for a customer and he never picked it up. It's still in the store room in a box. I'll dig it out tommorrow and see what it is for sure. It seems to me it was around $100. I'll let you know.
