Okay, I can deal with the alternator bracket as an engineering flaw with a quick fix.
I had a hard time understanding why I had to make 3 trips to the dealer for an air box mixing door/AC problem seein as how they have had heaters and AC in vehicles since way before I was born ... ... ..... not to mention the price tag ... ... ... ... . but I can deal with it.
Now this I am having a terrible time with.
I have already posted this to some degree, but I'm gettin mad now.
@ ~ 25,000mi I need a new rear drive shaft because the u-joints are shot and they can't get the assembly balanced with new u-joints.
@~ 50,000mi same situation with the rear driveshaft, but now I need a u-joint in the front axle and 2 new front hubs.
U-joints are on back order so I took my truck home. They were okay with that and didn't advise otherwise.
Yesterday I'm coming off the highway and this thing starts vibrating so bad it nearly took my eye teeth out!
I got out and crawled under it and the only play I can really find is in the carrier and the left front axle which I knew was bad because of the clinking coming to a stop and the tech @ DC who is on top of it all.
I try to drive off and it literally felt like the driveshaft was loose and beating the dents back up from the underside of the bed!
I finally limped the couple miles to my shop and finished up some work not knowing how I was gonna get home, but thinking f*ck'em they designed this POS!!!
So, a few hours later I fire up the trustworthy Cummins and head to the house ... ... ... ... . very little vibration
By the time I drive the 30mi home, the vibration is only as bad as it was when I took it in to DC
I'm starting to think it's the carrier and not the u-joints at all.
Beyond that, what truck needs rear u-joints every 25,000mi and front hub assemblies every 50,000mi?
Crazy.
Another thing I noticed. When you open your door to get out of this tin can, do you hit the door stop? I guess I do and imagine most people do. For some reason, my eye caught the hinge area the other day getting out ... ... ... ..... look at what the hinges are fastened to and how bad it deforms while simply opening the door. The motor may last 1000,000mi, but I'll prolly be without doors!!!!!!!
I'm done now!
On edit ... ... .....
I have another concern. My '99 4x2 dually needed ball joints some where around 70,000mi ... ... ... ... ... yeah, I'm looking foreward to that too Oo.
Crazy.
I'm done now!
