Originally posted by Doug:
Iceman,
I'm running Michelin 235/85R-16 with E load rating. I don't think the tires are the problem.
As Iceman said, tire pressure could be part of the problem. Unladen, your pressures should be in the vicinity of 55 front and 40 rear. Loaded with 2000 lbs. , you should probably have almost 65PSI front and 70-80 in the rear. Having the tires properly inflated does two things. First, it gives better control of the vehicle. Second, it reduces heat build-up in the tires; heat is probably the number one cause of unexpected tire failure (i. e. , one might *expect* tire failure after hitting a big, deep, chuckhole. )
Back when I had the OEM tires on my undervalved '98, whenever I carried a heavy load in it, I set the tire pressure to the maximum recommended (65/80); unladen, I ran 55/40. With the 19'5" Yokohamas, I use 55/70 unladen, and have (once) run them up to 75/90 carrying 4000 lbs. of horse dung.
With 2000-4000 lbs. in the bed, the only handling complaint I have is that the truck rolls (yaws?) noticeably when cornering; a rear stabilizer would cure this. I do have monotube KYB shocks on the truck, so it does ride fairly nicely empty or laden.
You should notice similar bobbing and weaving when empty or loaded (2000 lbs. is only 33% more weight). If there is a drastic difference, then tire pressure, shock absorbers, suspension bushings and track bar
(if 4x4) should be checked. I would expect the truck to 'wallow' if tire pressure is low; bob if the shock absorbers don't, and be generally hard to keep on the road if suspension bushings (and track bar, if so equipped) are badly worn.
Dunno about Ranchos for the old-gen trucks.
Fest3er
