A few years ago was "forced" into having the engine mounted fuel lift pump replaced with the in tank upgrade. Was just about to install a FASS system when this happened. Have a '98. 5 2500 5 speed with about 130,000 miles and truck is in stock condition. Readiing and evaluating replacement of the VP44 fuel pump and will probably purchase from Blue Chip Diesel. This is because of reading about sudden failues of the pump where it stops and need to have the truck towed. If do this would also like to install a FASS fuel pump and filter so have easier access for fuel filter replacement and more importantly good fuel supply pressure to the new VP44 pump. Does the intank lift pump need to be removed? Is it best to drop the tank or jack up the bed? What replacement hoses and electrical connections need to be modified?
Thanks for any suggestions and tips on doing this replacement.
