Engine/Transmission (1998.5 - 2002) In tank lift pump
Yesterday i went to install the Vulcan Big Line kit on my truck and use the Holley Blue lift pump. Well i saw the bracket for the stock carter on the side of the block but couldnt tell if the pump was there or not so i installed the kit. Well i guess the previous owner installed an in tank pump kit. Does anyone know what kind of gph or psi these things are designed for. Got a Quad Adrenalline that i wanna use on fuel levels. Thanks in advance.
Brian
The factory in tank pump does not function well, a WOT your fuel pressure can drop to O psi. I have an in-tank pump and I run it in series with a lift pump and it works well. The holley blue will last about a year before it starts leaking. I went through 3 of them and I am trying the other diesel lift pump sold at Advance and Auto zone. I cannot remeber the name of the pump but there are several threads talking about it.
Anyway you look at it, I wish that I had never went the intak route.
