Ok guys. Here's the story. After I talked to you David, I continued checking lines etc. and the only thing I can come up with is that it has to be at the retaining ring/ pump module seating. You can't screw up the fuel lines; they either "snap" on and hold or they don't (they were both tight). The electrical connector slides in and locks with the red sliding tab (as stated by the instructions), but this has no way to cause a leak. All hoses (old vent, new vent, and filler hose) are all dry (no cuts or holes).
When I took off the retaining ring, it was real snug and required a hammer and screwdriver to "tap" it loose to release. When I spun the ring off, the pump "jumped" up out of the tank about 3 inches because of the spring loads. When I reinstalled the pump (which only fits in one way) on the tank, I pressed it down (against the spring tension) and it never "sprang back up" like it did when I first unscrewed it. I then placed the retaining ring back on and spun it to the locked position. The ring had a little play after that and never really was "snug", and did not require me to hammer (tap) it back into a tight position. I thought to myself "hmmm, maybe the spring load of the pump has to force itself "up" against the retaining ring to help lock it tight and create a better seal (just a guess). So, I put it all back together and let it go thinking maybe the springs would eventually "pop" back up and seat.
Then for the fill-up. I hit 36 gallons and the fuel spill was on. About 2 gallons come spraying out from under the truck and the "oh
. . it" face was on. Raced down the highway a bit to burn off some fuel to get the level down and then back to the garage. Took off the rear wheel. Lowered the tank to the end of the straps. Checked everything out. No leaks at the new vent fitting, hoses, fuel lines, etc. So, it has to be the at the retaining ring.
Here's my question (finally). I don't remember seeing any type of O-ring or gasket. Is it possible I missed it and it fell into the tank somehow? There's nothing on the ground. If so, what color is it (black or maybe clear?) I'm trying to recall any items down in the tank that I might have overlooked. It seems that a gasket would have raised the pump enough to "snug it up" and helped to make the retaining ring go on more tightly.
Ok. The next step is to burn up my $100 new tank of fuel so that I can lower it again and recheck the pump/ring fitting.
BTW. The install went great. No problems (with any of David's product). And I can't wait to get this puppy fixed right so I can "top it off" for real next time. I just might hit $120 this time
