Engine/Transmission (1998.5 - 2002) in-tank pump removal help
Engine/Transmission (1994 - 1998) A/c Line Removal
Near the end of my warrenty- one month left. Recently had the VP44 replaced under warranty and HAD to do the in-tank pusher 1st. Low pressure warning light going off with any load (5 lb warning light). Hope new VP44 still OK since just put warning light in about 2 wks after new VP44 and did a long trip towing before installed light. Anyway, would prefer to just remove entire system and do better as some have posted. Is it best to remove and start over or add a second pump? How hard is it to remove in-tank pump.
Thanks
2001 2500, EZ, 4"exh, auto, closed waste gate
All you have to do
Is add a lift pump in the old stock location just power it up with the relay that powers up your in tank pump. If you do right you should see over 20psi of fuel pressure.
