The boost fooler only acts as a way to stop the ecm from reading any more than 20psi, it will not give you any more boost, but you will need it.
Chances are good if you have an auto, you have an HY, if you have a manual then you will probably have an HX. There is a identificaiton plate on the front of the turbo, it will tell you which turbo you have.
To adjust the wastegate is different on these two turbos, just do a search for 'disabling wastegate' + your turbo and you should find all the information you need.
-Rich
