Initial Flux 2 Injector Impressions
04 engine installation, not enough room!
EGT Concerns
JStieger
Before I give some initial observations I want to explain my thought process on why I went with a certain injector over another. Hopefully, this write-up can help other people trying to make a similar decision.
BACKGROUND INFORMATION
After 2 years of running extrude honed injectors I was starting to get tired of the boggy feeling off-idle, constant black smoke at low rpms, and the feeling that I lost some mileage. These observations seemed to increase more and more as I BOMBed my truck and they really made me start to think about spray angles and the importance of having injectors matched to the performance level of the truck.
EXTRUDE HONED VERSUS EDM... CHOICES, CHOICES,...
I've been toying with this thought for a few months and started talking to quite a few TDR and DTR people, EDM and honed injector vendors included. Of the people I talked to, I put more weight on the folks' opinions that have run both EDM and honed injectors versus the folks that have run only EDM injectors or only honed injectors. I will say that price was an issue at first with EDM versus EH - EDM was more expensive, but when one considers returning core nozzles with EH then the price becomes somewhat closer. In the end I decided to overlook price so that I could concentrate on the performance deliverables.
I first considered some smaller 50 HP DDP or Industrial Injectors in order to gain more TST adjustability back as well as to not dump a bunch of fuel in at once to drown the engine and bog it down. Many owners were extremely happy with their DDP injectors and their solid reputation and performance gains and such have been well documented elsewhere. I was generally fairly happy with my Industrial injectors, but they did cost me some mileage - about 0. 5 mpg less than my previous DD3 injectors. On the Industrial 3-flows I think I finally figured out how the "3-flow" name came out from some recent posts on DTR in regards to only 3 of the 8 holes being honed out versus all 8 of the stock 03-04 injector nozzle being equally honed out. Does DDP do this too? I don't know - and it made me think that if only 3 of the 8 holes were honed what would that do to spray pattern? Would the spray be biased more to one side than the other? Don't know, but this really reinforced in me that the honed holes in a factory nozzle originally set up for factory performance guidelines may or may not be the most optimized for our modded trucks.
The thought of having new EDM nozzles with new optimized hole placement appealed to me, especially with the mods we run that advance timing electronically or with fuel pressure. There's a post on the 12 valve forum that Jim Fulmer did that showed the injector spray pattern on a modded truck. The spray pattern was outside the bowl because the injector wasn't matched to the engine mods. I want something that is matched, in theory, to my engine mods!
The two vendors that do this (new nozzles with new holes) are Don M and Bosio. Bosio is very well respected in the international TDI world and European common rail world, but somewhat unknown in our small Cummins world. In fact, my DD3 injectors I had before my 3-flows had Bosio Sprint tips. Bosio tips are also found on some II injectors depending on supply-and-demand. The Bosios were not on my 3-flows, but what I do know is that when I had DD3 injectors with the Bosio's my mileage was about 0. 5 mpg better than my similarly sized 3-flows with Bosch tips. So this tells me that Bosio must be doing something very right with new nozzles with new holes; Bosio just doesn't have the brand ID here with the Cummins.
The other vendor is of course Don M and he does have the crazy cult-like following :-laf to the point that I was at a dyno event 3 years ago and a NW BOMBER dude got all belligerent on me when I mentioned that I was considering some honed injectors! Anyhow, after a bunch of emailing back-and-forth with Don I finally decided on his Flux 2's. They are 100 HP rated and a slightly finish honed version of his EDM Flux 1's, but geared more towards the folks with modded CP3s. Look at Gypsyman, AK Ram, Banshee, Idaho CTD for verifiable proof that Flux 1's work at +/- 600 HP levels. Yes, I repeat, they are running "small" 40 HP injectors and getting the same dynos as I with my "big" 90 HP injectors. Don was actually trying to steer me towards Flux 1's for meeting or beating my current power levels, but the modded CP3 was the wild card since 1's weren't targeted for a modded CP3 in particular.
INITIAL RESULTS
Are the claims of less smoke and EGT true?
So far I see:
-50 degrees less EGT at cruise at 75 mph. Yes, I couldn't freakin' believe it so I went on the interstate 3 more times to verify it.
-1/2 as much smoke and the smoke is more wispy grey than thick black. Before under 1500 rpm I could black out 2 lanes of traffic. Now the smoke level is about like AK Ram's 1/4 mile videos! My wife even commented on the smoke level being a lot less!
Are the claims of same or more performance true?
So far I see:
-no boggy, blaahh feeling off-idle or off low rpms anymore. It starts pulling and feels like when I had the cam installed at sea level.
-rail pressure comes up faster and holds longer by looking at the gauge readings under various driving conditions. This seems to be supported by the fact that under the same before and after TST/Smarty levels, I have more noticeable timing rattle now, where the timing rattle comes from the fuel pressure coming on earlier (equivalent to advanced injection timing.
Next up is dyno time... hopefully by the end of February when the weather gets better. I intend to dyno on the exact same settings on this thread:
https://www.turbodieselregister.com/forums/showthread.php?t=169669
Exellent write-up! I can't wait to see the dyno numbers. I can't wait till I have the money to get Fluxs in my truck.
Once again, great report... . Like always.
I will be doing the same thing soon i hope. I fell i have out grown the injectors i have now. They have been good to me. But i feel as you do after a certain point you have to have things just for your goal's. The stuff off the shelf just wont get you to were you want to be and that is on top! So down the road they may go they got me to 526hp 1062tq with tst. But I want more :-laf
did Don say if any of your injectors leaked when you sent them in? or did you buy complete new?
i had 5 leaking, dont know about the sixth, Don asked if i put the tips on?!
guess i got what i paid for ($300).
like you i went flux. live & learn but $ can be a factor sometimes.
Fortunately, he said that all my injectors checked out good. I am pretty easy on the rail pressure boxes though. They weren't my original stock injector bodies. My stock injector bodies had DD3 tips put on them by Dynomite Diesel about 2 years ago. Then my DD3 carboned up due to my driving habits so I traded them to Industrial for the 3-flows, which were already assembled before I got them. Don also checked my 3-flow tips and they checked out good (nothing broken) too.
Very good !!! You have probley saved folks some money by testing injectors. I bet it doesn't take you long to swap them out now. I'm not afraid to try something new "I bought one of the first Stage I cp3s" but injectors for the 04. 5s seem to have been hard to improve until now. Keep us up to date on the results.
Actually, these were the first set I changed myself. The other 2 I had DDP or Dynomite change. They definitely changed them more than a few hours faster than I did :-laf . Since I had them out of my truck for a week I forgot how they looked liked going back together so I had to call lmills and Jeff K on here for emergency advice. I also retorqued my head studs after getting some advice from jwilliams3.
As far as saving money, I don't know. Every style of injector has its place and truck application I guess. I too was skeptical of the Don M injectors at first and it took me a long time to warm up to the idea of trying them. Then you look on the 24-valve (I know, different engine, but... ) boards with the many members that have switched from honed to the EDM or Mach style - that has got to tell you something about the deliverables on these injectors. Here's a thread on DTR from a month ago asking about Flux 1 versus Flux 2 differences. There's a lot of info in there if you read between the lines a bit:
http://www.dieseltruckresource.com/d...d.php?t=128126
Can individual holes even be targeted by the honing process? I would love to know this! Also, for the record, I don't know for sure if the 3-flow injectors only have 3 out of the 8 holes honed out. I infered that information from abc4yew (a well respected DTR member) on this thread when he talked about 4 of 8 holes of his Industrial nozzles being honed out. I. e. , basically, if he was running bigger injectors with 4 of 8 holes honed out to support his Super C3. 4 pump, then it would stand to reason that my "3-flows" will only have 3 of 8 holes honed out. Incidentally, II also sells less power rated "2-flows" on their website.
http://www.dieseltruckresource.com/dev/showthread.php?t=131303
I would love to know if DDP equally hones out the spray holes or do they also do the same as Industrial. If DDP equally hones out the holes on a stock EDM nozzle, then the stock spray pattern would be preserved. If the stock spray pattern is preserved, then under normal driving conditions stock mileage, smoke, EGT etc. would also be guaranteed as a minimum.
(Quote)
know this! Also, for the record, I don't know for sure if the 3-flow injectors only have 3 out of the 5 holes honed out. I infered that information from abc4yew (a well respected DTR member) on this thread when he talked about 4 of 5 holes of his Industrial nozzles being honed out. I. e. , basically, if he was running bigger injectors with 4 of 5 holes honed out to support his Super C3. 4 pump, then it would stand to reason that my "3-flows" will only have 3 of 5 holes honed out. Incidentally, II also sells less power rated "2-flows" on their website.
Just for your information the 03-04 305/555 engine stock injectors have 7 or 8 holes. The 04. 5 to 06 have 5 holes and the Flux 1 & 2 for the 03-04 have 5 holes.
:eek: Thanks for picking up my error :eek: - I messed up and like an idiot assumed they were like my Flux 2 tips...
I didn't have a chance yet to closely look over my 3-flow tips. Can the naked eye detect if only some of the holes were honed or not?
Lightman said:
(Quote)
Really?
Mine had more than 5, but less then 8
Then again those darn holes are SMALL! So who really knows
My be if your vision was like a microscope but even then I don't think so.
If you remove the pin out of the end of the tip and use the tube that comes with the carb cleaner and insert in the hole and spray through them it makes it so you can see the holes with something coming out of them. a good magnifying glass works also :)
I cannot say for certain whether or not DDP hones all the holes out of the injectors or not but from watching the process and looking at the tips after the process is finished I would say all the holes are honed. My impressions were a 1. 5-2mpg gain in fuel economy when I went to the 90hp DDP injectors in my '03. EGTs I cannot comment on because the truck was stock with nothing then got gauges injectors and FASS all at the same time. My truck was a stock 47re with a stock turbo and NO electronic aids of any kind and I would classify its off idle performance as peppy not boggy. You are running a stick with BD twins so if you were experiencing a bog off the bottom I would say you had some messed up injectors.
Isaac
