injection problem?
03 with high pitch whistle or squeal when boost goes above 10 psi
03 hi fuel rail psi at idle
I need info on my injectors, I have 180,000.On the speedo and my engine feels different.
I am use to the engine and it( feels like if it were a gasser it would be missing a cylinder.)like it is running rough.
I was thinking about getting the injectors cleaned, any ideas.
fill out your sig. you need to add a 2 micron filter. once you have the filter installed call ddp and order the cleaner and run it in a tank of fuel. i think i have a can of it to get the name of the stuff, i will look for it but if you get it first post it here.
