I had about 47,000 miles on my truck when it happened. The check engine light came on. The owners manual says that it is a timing/emissions problem and you can still drive the truck, but have it checked. Since I did not notice anything amiss, all fluids were OK, I continued on to Mesa, AZ.
There I removed the EZ Edge chip and took it ti the Dealer. (With fingers crossed since it has only the power-train warranty now.
They fixed it-tilling me the following . Vehicle had a code for injection pump timing failure, so they replaced it. Transfer pump had low flow-replaced. I have the BD low pressure warning light but it never came on. Truck rung good and seems quieter.
CAlled Edge and they said that this injection pump was prone to problems, was weak-especially with low fuel flow. Send them the chip and they will check it out, I will. Also might install a booster pump. Already have the larger Banjo fittings.
Has anybody experienced anything like this?
