Injection Pump Faliure
front axle seals
no fuel
Hey guys, I was just wondering if there was any signs or things you can look for to determine if you injection pump is dying. Mine is still running strong, but I was wondering what the average life on a pump on these trucks was... . any signs to look for for a weak pump??
thanks
cody
91 4x4, 5 speed, 3. 54 gears, pw injectors, 12cm turbo housing, K&N air filter, "tweaked" pump, isspro boost and pyro gagues w/A pillar mount, straight piped 3' exhaust
I just finished replacing the injection pump on my '89. It had 190,000 miles. One thing that I have found is that I get higher RPMs with the new pump. Right before mine gave up completely the engine died twice in about 500 miles, then died completely.
'89 4X4, Banks intercooled, Banks Powerpack, 727 Auto, 3. 55 gears, GearVendors O/D, full guages, Ramsey winch, Transferflow 50 gal. tank, Alcoa rims, 265/75-16 tires, Chrysler trans cooler, National Spring 2. 5" lift springs, and a few odds and ends
Someone in the 1st gen discussion forum noted that prior to his pump failing, his fuel shutoff selenoid kept ketting blocked and plugged by small pieces of metal, from the internals of the pump. The symptom is your truck not shutting off when you turn the key off.
Not sure what other signs of pump failure are other than the obvious complete failure - mine has 153K in a 1992 and currently has a shutoff selenoid problem that I am tracking down.
jon
Injection pump failure+1st gen. =install P7100 pump+burn tire!
I can't wait for mine too die! I got everything turned ALL THE WAY UP trying to kill it but its still running strong @ 138,### miles.
  • '93 250 LE 4x4 5spd 4:10 Loaded,dual 5" chrome stacks,12cm² turbo(37psi),PW injectors,K&N,pyro/boost,US Gear E-Brake,tool box,CB,10" AR rims, 285/75/16 Bf goodrich. "wirenut_21529" on Yahoo Messenger
  • '97 Ford B-Series school bus (5. 9 Cummins!)I'm gonna Bomb it!
  • '94 GMC 2500 6. 5L Turbo
PICTURES.
I had a problem with my truck not starting this summer in around 98+ temperatures which was every day in texas. After I would drive it for about 20 minutes and turn it off... . it would not start up again. I would have to wait about 30 minutes to an hour until it would start again. I don't know what caused it, but I was afraid it was the pump. Now that it's colder, I haven't had any problems. The truck feels like it has lost a little top end power, but I'm not for sure about that. I have no tach to measure RPM.
My first injection pump failure happened three and a half years ago, on a very hot August day in Phoenix. I was returning home from from Tucson, and made it almost all the way before the truck died. Luckily, I was only 1/4 from my driveway. I noticed about halfway home, the truck did not have much power, and I had to mash my right foot to the floor to maintain 65 MPH. At the last few stop lights, the truck would not idle. The truck had 152K on the odometer at the time. When the truck died, the engine seemed to crank at a much higher RPM with the starter. Other than the symptoms just before it died that day, I had no other warning of approaching pump failure.
My second Injector pump failed at 194K, just over a year and a half ago. Again no warning signs of approaching pump failure. Luckily, it failed in my driveway and once again I did not have to pay the tow truck driver. Both times when the pumps were overhauled, the Bosch overhaulers claimed dried seals to be the primary cause of failure. My first overhaul lasted only 42K mi, and less than two years. I don't know if high engine compartment temperatures contributed to such a short pump life, or maybe just a bad overhaul. Anyway, I did not take it back to them for the second overhaul, and consider myself fortunate for not having it fail in the middle of nowhere.
89 D-250 LE 5 speed 3. 55 Limited slip, K&N, straight piped, Boost/Pyro. & 16cm2 215K and still going. 91 W-250 5 speed, 4. 10 Limited slip, 16cm2, 6" Skyjacker lift, RS9000, Dump bed, 18K original mi.
Hey Wirenut,
You can't wait for yours to fail? You won't be saying that when you are 200 miles from home and it quits on you. Especially when you get done paying the tow truck driver, and then price that minature inline six (P7100) and all of the associated plumbing that will have to go with it. An overhaul of the Bosch will set you back $400. 00 to $600. 00 depending on what kind of parts are worn out in it, and that doesn't even include the labor to remove and replace (and time) the injector pump to the engine.
