I have a few question for the injection pump guy's . I'm kinda in debate with the shop that rebuilt my pump,The history ,had the pump rebuilt and figured it would be a good time to get a 3200 gov spring added and advance the timing at the same time ,i got the truck back and it ran great about 1 month of driving the truck the fuel solenoid stuck open ,I called the shop and told them brought them the truck and they changed the solenoid everything was fine for another month well the solenoid stuck again so i called them and told them so they looked at the solenoid and the rubber tip on the solenoid was tore same spot as last time. The shop called me and said they wanted to take the pump off and take a look at it,everything should of been covered by warranty the receipt shows a warranty is intact. Well I get a call today and the shop owner tells me the gov spring is what is causing the tip to tear and say's I owe atleast 8 hrs ,Now for the question isn't the fuel solenoid on the low pressure side of the pump he did say that they set the fuel flow way high on the rebuild and that it was almost double stock flow now i just want to know about whether the solenoid is on the low side or not and he told me the pressure on the solenoid goes up with rpm which I can somewhat see but I can't see the lift pump supplying enough to rip the seal. Sorry about the rambling and the long post. I realize the whole modifications you are your own warranty but at the same time I cant see a gov. spring blowing out your fuel solenoid when so many others have the same setup . Thank's Joe
