Okay guys, I followed the suggestion to tighten the tappet cover bolts and now I think its leaking worse than before! So, I'm going to change it while messing with the injectors on the timing, blah, blah, blah.
Any quick tips on pulling the injection pump? I have the fuel lines off already.
I REALLY don't want to have to pull the front cover off again, so I'm interesting in knowing if I can turn the engine so the key is at 12 o'clock instead of 6 o'clock. I guess I should have painted the end of the pump shaft so I'd know, but I didn't, so any tips on that? (And, when I go to put it all back together, how do I get the pump at 12 o'clock instead of 6 o'clock).
Looks like I will have to remove the bracket for the power steering/vacuum pump? Any special precautions on that?
I'm going to have a few beers and hope ya'll have the answers by the time I get back
-brian
-brian
