Injection pump replaced.
New 600 data sheet
two issues w/04.5 600
I had to have my injection pump replaced. It had a leak on the lower plug. (There are 3 plugs that look like freeze plugs). Does anyone know what kind of pressure the fuel is at under these plugs? I'm just wondering if this is the low pressure side or the high pressure side of the pump.
Thanks, Wayne...
P. S. I also had the power steering hose TSB done. Made a big difference. No more vibration between 2000 and 2200 rpm.
WOW! How many miles were on the truck when this happened? What did the job cost (I assume it was under warranty, but they must have given you a complete invoice)?
I had the exact same two things done about a month ago. I couldn't tell where the leak was on my pump, it was out of sight somewhere on the side facing the engine. The steering hose removed about 90% of the vibes I had.
