Injector 4
Lamp out Warning
??? on Rickson 19.5 FORGED aluminum offset
Someone suggested I check #4 as the lines are prone to breakage.
At 190K Everything is tight, but around the injector looks like it was wet once and collected dirt/dust. It is still (moist?) not the right word, but how oil collects dirt and then gets that moist look.
None of the other injectors have this around them?
Guessing I need to do a steam clean and see what shows up at a later date.
Going to order from Geno's. Local Stealership wanted $75.
Being completely ignorant of these engines will I need to bleed air out, or is this just a R+R?
As always and in the future. Thanks for the info. Using others experiences is always better v/s stumbling through the dark by myself.
