Engine/Transmission (1998.5 - 2002) Injector body and tip question?
Engine/Transmission (1994 - 1998) Too Much Turbo ??
D
2nd Gen Non-Engine/Transmission Brake Tools?
Does a HO engine have the same injector body as a non HO engine? And then the next logical question is can i put new tips on a set of non HO stock injectors that i have and insstall then in a HO truck?
I think the ijectors are the same, cause when you order them they dont ask you if you have a HO or non-HO. So I would say yes you can put tips on them and install them on either engines. I didn't have any issues ordering/installing Jammer 3 tips on my non-HO.
I think the difference with the HO and non-HO where the injector pumps and ECM programs. I know when you order a injector pump they ask you if its HO or not.
The bodies carry a different part number although internally they are the same. The difference in the body number differentiates the tip.
If you swap tips, then the bodies are the same.
