As a post for someone else! What is the trick to getting the air out after an Injector change? Cycle the ignition switch(bump starter) to run the lift pump(with a few injector lines loose) still no fuel to the lines, purge the lines at the banjo bolts with a few bubbles, what gives, the truck was running fine but he did change the fuel filter prior to the injector change and ran it for a few minutes... ..... sounds like air to me but I'm a 12V guy... ... ... . there easy!
Jim
Jim
