Injector connector tubes
throttle position sensor 1999 dodge diesel
Diesel Power fuel additive
Talked to another TDR member the other day and he mentioned that . 093" connector tubes would be a good way to get more power. Then I happened to see "high flow connector tubes" for sale on the Haisley machine website.
Does anybody have these?
What will they do for me?
Paul
I am running the . 093 connector tubes from Haisley's. They make the truck lope a bit at idle. :) I installed them at the same time that I o-ringed my head and added twins to the truck. With all of those changes I lost 1Hp and gained 104ftlbs. My truck will now white smoke for a bit when you let off after a hard run and it you drive at around 2300 rpm in 1st or 2nd gear with no load the truck will develop a slight surge and start to white smoke as well. The main reason that I added them was for the sound. The may react differently/better with a hot rod pump and larger injectors.
