POD's ARE IN ! Yes, that was an awesome road test in a first gen
Jbolt, thanks for the help, I couldn't wait, so I mic'd the coppers out, and went with the . 020's what a difference
Gettting the injectors out was a real PITA though, had to use a slide hammer, and they were all carboned up and yuck. No smoke at idle, and a fair amount to a lot at WOT, boost went up at cruise about 1-3psi, and at WOT, I have not held it there to see, kind of scary, but I did manage to see 32 psi on one pull, yes a wee bit-o-turbo-bark if one changes mind on throttle posistion quickly during certain loads
I did let the thing rip at about 90% throttle, and saw 1250 EGT, a lot less than I had expected. Anyhow, the power across the band is tons better, and I have not changed my pump settings from the old injectors. The idle is nice a smooth, a bit lower, but about dead right because my pump settings with the old injectors jacked-up the idle a little.
For a truck with 185,000mi, it runs better than ever! Thanks to Nascar Mark, Harry, Piers and the PDR Gang over the boarder for the great product and service!!! Another note: Ever notice how easy it is to locate parts on their website, you can locate bombs faster than burgers in line at the fast food joint..... not good for my wallet
Thanks,
Russell
