Injector failures through codes?
My own Torque Tube - using the factory parts !
Bad, Bad, Bad, News
No code for injector failure, But -
P0201 - Fuel injector 1 Circuit
P0202 - Fuel injector 2 Circuit
P0203 - Fuel injector 3 Circuit
P0204 - Fuel injector 4 Circuit
P0205 - Fuel injector 5 Circuit
P0206 - Fuel injector 6 Circuit
P0301 - Cylinder 1 misfire
P0302 - Cylinder 2 misfire
P0303 - Cylinder 3 misfire
P0304 - Cylinder 4 misfire
P0305 - Cylinder 5 misfire
P0306 - Cylinder 6 misfire
Hope this helps.
I have the service manual with the codes listed, thanks for the info as I sure others can refernce the numbers.
What I need to know is if anyone with an injector failures where the injectors hung open and dumped fuel caused a code such as a misfire code.
Would like to know as I think the injectors in my truck are dumping too much fuel and increasing the oil level. The oil is BLACK in only 400 Miles since I changed it!!!
