Engine/Transmission (1998.5 - 2002) Injector Help
Engine/Transmission (1998.5 - 2002) Code 1114
2nd Gen Non-Engine/Transmission Where can I get these stripes!!!
Ok I Was On Ebay Looking At Injectors And Came Across An Ad That Said It Was The Injector Nozzles Not The Actual Injectors. My Question Is If I Buy Bigger Injectors For My Truck Do I Also Have To Buy Injector Nozzles. I Have Diesel Experience Just Never Messed With Injectors On Them. Thanks Adam
usually, when people talk about changing injectors, they are a complete unit. There is no need to break the injector down and swap nozzles.
Dave
The injector body is the same for stock and high hp. The reason so many places are selling just the nozzels is to save money but If You go this route You really need to have an injector shop do it and the set the pop presure. Most of the retailers tell You that this is not needed but I have done 2 sets this way (first set I put on new bodys) and both times they needed worked on to get it right. Even with the charge for pop testing and shiming it can come out cheaper but if You do not have A spare set to build them on You will have more down time on the truck.
i just installed 100hp injector nozzles from City Diesel this weekend and have had NO problems, they work exactly as advertised, make nice smooth (and smokey) power. combined with my TST3, it pulls like a freight train, so does the pyro needle though. the install was very basic and straightforward, even for a orangutang such as myself. for 285 bucks, hard to beat... others have had good luck with the City Diesel nozzles as well...
