In general terms... as you go "up" in injector size some basic things change...
1) Number of holes (though not always)
2) Pop-off pressure
3)spray angle
You can have 4 hole 5 hole, and more depending on who's nozzle your using.
Some are extrude honed, which is basically pumping an abrasive thru a given injector. This abrasive smooths and rounds the holes out for more flow, less flow resistance and other characteristics...
The spray angle can change as well. It is important to have the spray angle within a certain range for a given application to keep the fuel cloud in the piston bowl. .
The pressure that the injector releases fuel is called pop-off pressure. Usually the larger the nozzle the higher the pop-off pressure. Since it's sending in larger amounts of fuel it needs a higher pressure to keep a well atomized cloud, OR, you need more smaller holes at the same pressure, as an example.
The Bosch 185's are a nice injector. They give a decent boost in RWHP and do help in acceleration, and overall top end.
The POD's (Lucas) are the same over again... they will typically give in the range of 50-58 RWHP and make one heck of a difference in the overall power.
POD's do have a bit of hazing at idle or low boost. However almost any injector will do that if the pump is not set up properly, or you have air in/ air out restrictions.
You can "detune" your pump a fair bit and still get more out of the POD's than you can with the smaller 185's.
The more you can ease up on your pump, the longer it will last.
It's likely that in the future you will want to play with a bit more HP so I'd say go with the POD's and pump tune accordingly.
There isn't that much difference in the cost and you will get the entire install kit, with proper washers, and balanced/tuned injectors from PDR.
Just my opinion here...
bob.
