Getting geared up to replace the injectors on a buddies 04. 5. I've read the great install procedure posted on here and it seems to be pretty straightforward. My biggest question/concern is getting access to #5 and especially #6. Is there enough room to get back in there with the appropriate wrenches/pullers without having to lift the cab or anything like that? Seems pretty tight back there. Also, is there a way to turn the engine to TDC without a barring tool? Thought I read somewhere you could turn it somehow off a bolt on the damper. Any other helpful hints will be greatly appreciated.
