Originally posted by lmills
Yeah you don't need to remove them all the way, but you do need to pull them out slightly in order to remove and reinstall the injectors. If you force the injector in or out while the tube is in you run the risk of damaging the end of the tube. This will set you back about another $90 to get replacement tubes. [Thanks for the info. Should make the job a lot easier. hutch/QUOTE]
