I got the injectors in the truck today and I'm wondering...
The hold down clamps for the injectors, they aren't supposed to sit flush against the block, correct?? I torqued them down to 85in/lbs.
The other question, does it make sense that the nut holding the fuel line would screw in further on 1 cylinder? #5 tightens down between 1/16-1/8" farther than than other 5. I un did it and pulled out the connector tube, all seemed ok.
I just want to make sure I did this right before I crank it up.
Thanks
Nate
Thanks
Nate
