I have a 2006 5.9 I just bought this truck and rebuilt it. The owner before me ran crude oil through the motor for fuel. I changed the pump in the fuel tank and drained all the bad oil in the fuel and finally got it going. After I got it going I noticed it had a rough idle, almost like a lobe idle. I took the injectors out and sent them to Area diesel to get them tested, all the injectors came back bad, I got them rebuilt and received them last night. Just got them put in and now the truck runs worse then before, it white smokes at startup and at idle. Run really rough and the motor has a different sound to it. Would this still be an injector Problem? or is it something else? Ran the codes on the truck and all it shows is a Skim Key code.. Need Help ASAP!
