Injector leaking on engine!
Advantages of 4in exhaust
Anyone got powershot 2000 propane
I have an injector that is leaking onto the engine. There is a fuel line to the injector and the fuel return line, both seem tight. Could the injector have come loose or the seal gone bad?
Leak
Doubt that a loose injector would cause a fuel leak, but I have seen a cracked injector line or two in my time, Just a possiblility for you to check on.
A Loose or not to spec injector will indeed cause a leak. the best way to tell if it is a loose injector is to wipe all excess fuel from around the injector, then start the engine and look for tiny air bubbles around the holddown nut. if you have air you have a leaking injector. if not look for a cracked or loose line.
Don
When I bought my truck two where leaking right were they went into the head / Replace all the seals including the banjo seal . About an hour for a dealership to do... Don't worry its an easy fix and if you don't have the tools its cheap at a dealership
