Engine/Transmission (1998.5 - 2002) injector nozzles poll
Engine/Transmission (1998.5 - 2002) Drone ore something else?
I have the BD tips 130hp, I like them but probably should have gone with the 100hp tips. The power is great but they are a bit hot. I think they are great for the cost but i think the F1's are probably the best injecter you can buy. I guess it boils down to you get what you pay for. I got a smoking deal on the tips and at the time could not afford a set of F1's. I think i could make the same power with less egt's with the F1's. I have not hit the rollers yet but the power is awesome justa bit warm.
Steve
Im using jammer 3's on a 98. 5 with stock hx-35 and a taped comp. Way Too Hot!
It's real strong' but egt's will hit 1500 fast and 30 lb boost will peg.
ok for short bursts, (hot rodding) but I wouldnt try towing with this set-up
need bigger turbo
I have a banks powerpack. It's there ottomind box, larger turbine housing, intake, 4 inch straight pipe, stock transmission, stock turbo, 35 inch rubber with 411 gears.
Do you think jammer 3's are too much. I don't tow, I just drive it hard.
pretty sure you will toast your transmission. i know mine didnt like my TST 3 very much, but get it done and done right the first time, you wont regret it
I have DON M 1. 6"s and I am very happy with the added power. The injectors don't add much heat even with the stock turbo. After a few months with extra power your stock transmission will not be happy :{ . Mine started slipping in overdrive a few months after I added the edge comp (untapped). So I got the full DTT :-laf and added the injectors. Adding power is a slippery slope :D :D
Thanks for all of the replys. I have been waiting for a while to do this. My main issue is that it is a "company vehicle" so until the transmission goes I not getting a new one. Otherwords, if its not broke its not getting fixed.
