Injector Puller
Transfer Case discrepancies?
Clutch pedal almost gone (G56) stock <help>
StanHolder
Ordered injectors and the tools to replace them last week. However, it appears the injector puller 9010 from SPX is back ordered. I may not get it for weeks. Is there somebody else that carries the injector puller for the 2006 5. 9 CTD. I am suppossed to have the cores returned by the 31st. Hope the DieselStore can extend this.
I have replaced mine twice with out any special tools
Other than a torque wrench.
Just pry real easy on the injector and it will pop right out.
Dennis
Same as above didn't need any tool for injectors.
I did need tool for injector tubes, had 2 that
wouldn't come out.
After the hold down bolts are removed it is only the o-ring that keeps it in place ;) easy with just a tug. If you have a good grip you can pull it out by hand
