injector pump and computer
When do you check your front end lube?
trans fluid change
for what reason would my injector pump and computer have void stickers on them i bought the truck used and was not told every thing looks stock to me
Welcome to TDR
The reason for the void sticker is to prevent people from using fueling boxes. If the sticker is broken then the warrantee is voided. :(
Take some WD-40 and spray the stickers, they will peel off easily. Then take some more and clean all the glue off. Not all trucks had them and DC does not know which did and which did not. No stickers = no broken stickers to bother you about your warranty.
Do you mean to tell me that some people actually knowingly void their warranty for more power ??? ;) :D :D :D Say it's not so :eek: .
Scott W.
I would think that DC could look up the engine serial number build date and tell if the pump should have stickers, They probably wouldn't do this for minor work but for major engine work they will do what ever they can to void your warranty.
One of the vendors sell the void stickers to replace when going in for warranty work. I don't remember which one it is maybe someone will chime in and let you know.
Ron
I don't know why DC picked the injection pump connector and the ecm connector as the only two places to put those stupid VOID stickers. Obviously they don't know we build 400hp monsters without ever touching the pump connector and ecm connectors!
