I'm going nuts here with this one. I have a build up of oil, dirt etc on the of the upper drag link, about an inch inboard from the steering box. You can scoop the remains off by hand and roll it into a ball of soft dirty oily shhhh, which has accumilated since late May. Only place I figure the oil's coming from is a 5/8" hose that comes out of the top of the injector pump gear access cover. The hose is definitly factory as it has pre-formed bends and a clamp that prevents it from being sucked into the fan. The hose is directed up from the cover an inch or so, then 180 down till it turns at the bottom of the cover then drops straight to about an inch to the right of the steering box. Here's the only thing I can find in the shop manual (for hours last night - section 9, I think, in the Diesel Engine sector) is the access cover, seal behind it, then the cover plate?
Is this some means of ventillation for the gears churning behind the cover and is a tiny bit of oil OK/Normal? Did they leave it out of the shop manual just to give us something to do late into the night?
Also, is there a better way to bleed off the fule filter than just letting it dump on the front differential? I'm thinking of lengthening the hose to promote the use of a catch can figured I'd see what you guys were doing first.
Thanks
Thanks
