Is there anyone who can give me any pointers for installing an old pump with a new gear into a new engine?
Thanks
Art
Thanks
Art
Originally posted by DJP
Scot,
I had my injector pump rebuilt twice already, and both times when I installed it, I just used the TDC plunger (just below the injector pump mount pad) to time the injector pump.
The keyway on the injector pump drive should be locked in the 6 O'clock position when you get your pump back from the overhaul shop. I just simply used the TDC plunger to locate TDC, and aligned the notch on the injector pump with the mark on the mount pad. Although true Top Dead Center should be properly established, and the pump timing should be set properly with the dial indicator and correct plunger, you should be able to get your truck to run OK just by doing what I did. For optimum performance, you can either invest a few hundred bucks in tooling, or take it in to a shop to have the timing set properly. Both times I installed my pump this way, and the truck ran fine afterwards. It's your money.
