Injector pump problem/replacement needed any help would be appreciated
Water in Fuel
Brake Repair Questions
Has anyone have a clue to know which injector pumps were defective?Anyone who has had a defective or one go bad what were your symptoms?Also anyone know the cheapest place to get one of these vp44 pumps?My syptoms are you get a miss at various speeds most noticeable on the highway just like a skip on a gasser and could notice it today on the dyno screen or if anyone has any suggestions please sumbit. I have new dd11's new fuel system with carter pump 15 psi at a idle 11 with blue box foot thru radiator. thanks for your help.
99 24v auto 3500 4x4 reg cab 3. 55 axle,ez edge,275 injectors,k&n,rhino lining, tinted glass, tonnoue cover heavy duty trailer tow set up goose neck hitch draw tite brake setup,cb,cd player,catz back up lights,amsoil frnt to back,jre exhaust4 wire blue box,bd exhaust brake,transgo shift kit, a pro torqe extreme convertor, and a magtec trans cover and trans guage,JRE fuel line kit,upgraded fuel pump,braided fuel lines from lift to injector pump,reflashed ecm,fuel pressure guage,3 guage pillar,boost&pyro
Did you have the skip before the new injectors and fuel pump? If not could be one of those.
99 2500 QC 4X4 AUTO SB 24V LARAMIE SLT 3. 5 LSD 285-75-16'S SPA Boost/EGT Everything but leather NRA Member Great Lakes TDR Member
yes i have had this situation for a long time getting real bad now nothing to do with the injectors or lift pump thanks keep them coming men
Massdiesel,
Might want to consider buying a Cummins reconditioned injection pump. I seen posts where they cost around 1200. 00 from Cummins. They are supposed to be better than the old VP44. These have the better seals.
Is your truck under warranty?
Charles
2000 QC 2500 4x4 LWB ETC 6 Speed Anti-Spin 3. 54 Trailer Tow, DD1's, Practical Solutions boost module
1969 Toyota FJ40
350 TBI, Turbo 400, ARB lockers front/rear, 4 wheel power disk brakes, 4. 88 ring/pinion, 3 speed transfer case, full roll cage, Warn 8274, MRT 36 bolt beadlocks with Super Swamper Boggers (16x35x15), Saginaw Power steering, custom bumpers/fenders/nerf bars. Conquered Tellico and going to Moab this May. Loves to be pulled behind the Dodge and pass the powerjokes going up hills.
A couple days before my 98. 5 died, it developed a loping idle after the engine had warmed up. Was running great across NV and when I pulled off the freeway in the evening to get a motel room I first noticed that I had a loping idle. Drove it to San Francisco where it died a couple days later. Was running great, just wouldn't idle good after it warmed up, when loping it the rpm would vary by a couple hundred rpm.
mine died going down the highway, truck ran great until it stalled and wouldnt crank over and start again.
1999 2500 Quad cab 4x4 auto,Forest Green Sport,Banks Stinger-Plus,Smittybilt nerf bars,Smittbilt Outland grill and brush guard,Tuff Country leveling kit with SX 8000 shocks.
Fj 40 under warrantty but i peirced the wire so i dont they will do anything
Mass, check with Chip at Blue Chip Diesel. He is as knowledgeable on the injector pump issue as anyone. He also told me that he would sell the injector pump as cheaply as anyone. You might want to get it to his place for repairs. I would.
